SMTP - notifications
Hello, I really like this project.
I’m wondering if there is an area that discusses the configuration of SMTP for notifications. I cannot seem to find the documentation. I did a search for “SMTP” in the web help page, but nothing was found.
So, then it doesn’t seem like notifications will work. If this is stored in a config file somewhere, I’m happy to poke around… with a bit of direction.
Help…
Do you use the cloud version or a self-hosted version?
We are using the self hosted built from the documentation on Ubuntu 18.04.
Hi jco3,
welcome to the SeaTable Community Forum!
You guessed right: Unless an SMTP is configured, SeaTable will not send any messages/notifications. SeaTable does not come bundled with a mail server. It rather uses an SMTP account on a remote mail server to relay messages.
Regarding configuration: Does this answer your question?
Either would be fine with me. But I do not see any place where the SMTP account can be specified… and I cannot find anything in the documentation. Maybe I’m looking in the wrong help area.
A link would be sufficient if you can assist.
Hi jco3,
I am sorry. The bit about smtp configuration in my answer was a bit short and ambiguous.
Please have a look at the link burried in my answer. I am pretty sure that contains the info you need.
Ah… thank you. I will certainly bookmark that manual link.
Thank you!
Glad the linked helped!
Would you be so kind and mark the thread as solved.
If I had any clue on how to mark as resolved… I would.
