Hi everyone,
I wanted to share a Python script that sorts the options of a single-select column alphabetically without deleting and recreating the options.
The goal was to reproduce the same behavior as manually reordering select options via drag & drop in the SeaTable UI:
preserve existing option IDs
preserve colors and text colors
do not delete options
do not recreate options
do not read or modify row values
only change the order of
column.data.options
Background
I first tried the obvious documented REST approaches:
Updating the column via
/columns/and passing updatedcolumn_data -
Updating options via
/column-options/
However, in my test environment:
/columns/did not accept thecolumn_dataupdate for this use case. -
/column-options/accepted the payload, but did not persist the changed order. -
The actual UI behavior appears to use an internal
modify_column_dataoperation.
The working approach is therefore to send an internal DTable operation:
"op_type": "modify_column_data",
"table_id": "0000",
"column_key": "...",
"column_data": {
"options": [
The script sends this operation via Engine.IO polling to update-dtable, similar to how the web client updates the base.
Safety measures included
The script includes several safeguards:
DRY_RUN -
explicit confirmation flag for the undocumented internal operation
before/after JSON output
verification that option IDs and metadata remain unchanged
verification that the saved option order actually changed after the update
no row reads or row updates
Tested result
In my test table, the original order was:
Eins
Zwei
Drei
Vier
After running the script, the saved order became:
Drei
Eins
Vier
Zwei
The option IDs, colors and text colors were preserved.
The server acknowledged the update and increased the dtable_version.
Important caveat
This uses an internal, undocumented modify_column_data operation. It works in my environment, but I would not treat it as an officially supported API contract.
I am posting this for two reasons:
It may be useful for others who need to reorder select options without destroying option IDs.
I would be interested to know whether there is an officially supported API endpoint for this use case, or whether SeaTable plans to expose one.
Script below.
# -*- coding: utf-8 -*-
SeaTable/BwTable: Select-Optionen ohne Löschen/Neuanlegen sortieren.
Finale Version: Engine.IO-Polling, keine python-socketio-Abhängigkeit.
Ziel:
- Reihenfolge von Single-/Multiple-Select-Optionen alphabetisch sortieren
- KEINE Optionen löschen
- KEINE Optionen neu anlegen
- KEINE Zellwerte lesen oder verändern
- Option-IDs, Farben, Textfarben und sonstige Options-Metadaten erhalten
Technischer Ansatz:
- SeaTable speichert die Optionsliste in column.data.options.
- Der Webclient ändert diese Metadaten intern über die Operation:
op_type = "modify_column_data"
- Diese Operation wird über Socket.IO / Engine.IO an update-dtable gesendet.
- Der öffentliche REST-Endpunkt /column-options/ ändert die gespeicherte Reihenfolge nicht zuverlässig.
Sicherheitsmodell:
1. Erst mit DRY_RUN = True ausführen.
2. Ausgabe prüfen.
3. Für echte Änderung setzen:
DRY_RUN = False
CONFIRM_UNDOCUMENTED_SOCKET_OPERATION = True
Hinweis:
Diese Lösung nutzt einen internen Webclient-Mechanismus. Funktioniert wie Drag & Drop,
ist aber nicht als offizieller stabiler REST-Endpunkt dokumentiert.
from seatable_api import context
import copy
import json
import time
import unicodedata
import requests
# KONFIGURATION
# Standard: aktuelle Tabelle aus dem SeaTable-Script-Kontext.
# Alternativ fest setzen, z. B. TABLE_NAME = "Table1"
TABLE_NAME = context.current_table
# Name der Single-/Multiple-Select-Spalte
COLUMN_NAME = "Status"
# Erst True lassen. Für echte Änderung auf False setzen.
DRY_RUN = True
# Harte Sicherheitsbremse für den undokumentierten internen Socket-Mechanismus.
# Für echte Änderung bewusst auf True setzen.
CONFIRM_UNDOCUMENTED_SOCKET_OPERATION = False
# "asc" oder "desc"
SORT_DIRECTION = "asc"
# Deutsche Sortierung: Ä->Ae, Ö->Oe, Ü->Ue, ß->ss
GERMAN_SORTING = True
# Leere Optionsnamen am Ende halten.
EMPTY_NAMES_LAST = True
# Technische Parameter
REQUEST_TIMEOUT = 30
VERIFY_RETRIES = 10
VERIFY_SLEEP_SECONDS = 0.5
SOCKET_LANG = "de"
# Diagnoseausgaben
PRINT_BACKUP_JSON = True
PRINT_OPERATION_JSON = True
# JSON / AUSGABE
def pretty(value):
return json.dumps(value, ensure_ascii=False, indent=2, sort_keys=False)
def compact_json(value):
return json.dumps(value, ensure_ascii=False, separators=(",", ":"))
def print_section(title):
print("")
print(title)
print("-" * len(title))
def mask_sensitive(value):
Verhindert versehentliches Ausgeben von Tokens in Diagnoseobjekten.
sensitive_keys = ("token", "authorization", "cookie", "jwt", "secret")
if isinstance(value, dict):
result = {}
for key, val in value.items():
key_text = str(key).lower()
if any(marker in key_text for marker in sensitive_keys):
result[key] = "***"
else:
result[key] = mask_sensitive(val)
return result
if isinstance(value, list):
return [mask_sensitive(item) for item in value]
return value
# SORTIERUNG / OPTIONSPRÜFUNG
def normalize_sort_value(value):
value = str(value or "").strip()
if GERMAN_SORTING:
replacements = {
"Ä": "Ae", "Ö": "Oe", "Ü": "Ue",
"ä": "ae", "ö": "oe", "ü": "ue",
"ß": "ss",
for src, target in replacements.items():
value = value.replace(src, target)
value = unicodedata.normalize("NFKD", value)
value = "".join(char for char in value if not unicodedata.combining(char))
return value.casefold()
def option_sort_key(option):
return normalize_sort_value(option.get("name", ""))
def sort_options(options):
direction = SORT_DIRECTION.lower().strip()
if direction not in ("asc", "desc"):
raise Exception("SORT_DIRECTION muss 'asc' oder 'desc' sein: {}".format(SORT_DIRECTION))
reverse = direction == "desc"
# Wichtig: Bei reverse=True sollen leere Namen trotzdem am Ende bleiben.
if EMPTY_NAMES_LAST:
named = []
empty = []
for option in options:
name = str(option.get("name", "") or "").strip()
if name:
named.append(option)
else:
empty.append(option)
return sorted(named, key=option_sort_key, reverse=reverse) + empty
return sorted(options, key=option_sort_key, reverse=reverse)
def option_id(option):
value = option.get("id")
if value is None or str(value).strip() == "":
return ""
return str(value)
def option_ids(options):
return ["id:{}".format(option_id(option)) for option in options]
def option_identity_minimal(option):
Knappes Anzeigeobjekt für Logs.
result = {
"id": option.get("id"),
"name": option.get("name", ""),
if "color" in option:
result["color"] = option.get("color")
if "textColor" in option:
result["textColor"] = option.get("textColor")
return result
def canonical_option(option):
Vollständige, stabile Repräsentation einer Option.
Damit prüfen wir, dass nur die Reihenfolge geändert wird.
return json.dumps(option, ensure_ascii=False, sort_keys=True, separators=(",", ":"))
def validate_options(options):
if not options:
raise Exception("Keine Select-Optionen gefunden.")
ids = []
for index, option in enumerate(options, start=1):
oid = option_id(option)
if not oid:
raise Exception("Option an Position {} hat keine ID: {}".format(index, pretty(option)))
ids.append(oid)
duplicate_ids = sorted({oid for oid in ids if ids.count(oid) > 1})
if duplicate_ids:
raise Exception("Doppelte Option-IDs gefunden: {}".format(pretty(duplicate_ids)))
def assert_same_options_before_after(before, after):
before_by_id = {option_id(option): canonical_option(option) for option in before}
after_by_id = {option_id(option): canonical_option(option) for option in after}
if set(before_by_id.keys()) != set(after_by_id.keys()):
raise Exception(
"Abbruch: Optionsmenge/IDs unterscheiden sich.\nVorher:\n{}\nNachher:\n{}".format(
pretty(sorted(before_by_id.keys())),
pretty(sorted(after_by_id.keys())),
changed_payloads = []
for oid in sorted(before_by_id.keys()):
if before_by_id[oid] != after_by_id[oid]:
changed_payloads.append(oid)
if changed_payloads:
raise Exception(
"Abbruch: Mindestens eine Option wurde inhaltlich verändert, nicht nur verschoben: {}".format(
pretty(changed_payloads)
def print_options(title, options):
for i, option in enumerate(options, start=1):
color = option.get("color")
text_color = option.get("textColor")
suffix_parts = []
if option.get("id") is not None:
suffix_parts.append("id: {}".format(option.get("id")))
if color:
suffix_parts.append("color: {}".format(color))
if text_color:
suffix_parts.append("textColor: {}".format(text_color))
suffix = " [{}]".format(", ".join(suffix_parts)) if suffix_parts else ""
print("{:>3}. {}{}".format(i, option.get("name", ""), suffix))
# REST API: APP ACCESS TOKEN / METADATA
def get_base_access():
server_url = context.server_url.rstrip("/")
url = "{}/api/v2.1/dtable/app-access-token/".format(server_url)
response = requests.get(
url,
headers={
"Authorization": "Bearer {}".format(context.api_token),
"Accept": "application/json",
timeout=REQUEST_TIMEOUT,
if not response.ok:
raise Exception(
"Base-Token Fehler: HTTP {} {}".format(
response.status_code,
response.text[:1000],
data = response.json()
if not data.get("dtable_uuid") or not data.get("access_token"):
raise Exception("Unerwartete app-access-token Antwort: {}".format(pretty(mask_sensitive(data))))
return {
"server_url": server_url,
"api_root": "{}/api-gateway".format(server_url),
"base_uuid": data["dtable_uuid"],
"base_token": data["access_token"],
def api_headers(access):
return {
"Authorization": "Bearer {}".format(access["base_token"]),
def api_url(access, path):
return "{}/api/v2/dtables/{}{}".format(
access["api_root"],
access["base_uuid"],
path,
def api_get(access, path, params=None):
api_url(access, path),
headers=api_headers(access),
params=params,
if not response.ok:
raise Exception(
"GET Fehler {}: HTTP {} {}".format(
path,
return response.json()
def get_metadata(access):
data = api_get(access, "/metadata/")
return data.get("metadata", data)
def find_table(metadata):
for table in metadata.get("tables", []):
if table.get("name") == TABLE_NAME:
return table
available = [table.get("name") for table in metadata.get("tables", [])]
raise Exception(
"Tabelle nicht gefunden: {}\nVerfügbare Tabellen: {}".format(
TABLE_NAME,
pretty(available),
def find_column(table):
for column in table.get("columns", []):
if column.get("name") == COLUMN_NAME:
return column
available = [column.get("name") for column in table.get("columns", [])]
raise Exception(
"Spalte nicht gefunden: {}\nVerfügbare Spalten: {}".format(
COLUMN_NAME,
pretty(available),
def fetch_current_column(access):
metadata = get_metadata(access)
table = find_table(metadata)
column = find_column(table)
return table, column
# ENGINE.IO / SOCKET.IO POLLING
def parse_engineio_packets(raw_text):
Engine.IO v4 Polling kann mehrere Pakete mit Record-Separator \x1e liefern.
if not raw_text:
return []
if "\x1e" in raw_text:
return [part for part in raw_text.split("\x1e") if part]
return [raw_text]
def parse_engineio_open_packet(raw_text):
packets = parse_engineio_packets(raw_text)
for packet in packets:
if packet.startswith("0"):
return json.loads(packet[1:])
raise Exception("Kein Engine.IO Open-Paket empfangen: {}".format(raw_text[:500]))
def polling_get(session, url, params):
response = session.get(url, params=params, timeout=REQUEST_TIMEOUT)
if not response.ok:
raise Exception(
"Socket.IO GET Fehler: HTTP {} {}".format(
return parse_engineio_packets(response.text)
def polling_post(session, url, params, payload):
response = session.post(
url,
params=params,
data=payload,
headers={"Content-Type": "text/plain;charset=UTF-8"},
if not response.ok:
raise Exception(
"Socket.IO POST Fehler: HTTP {} {}".format(
return response.text
def wait_for_socket_ack(session, url, params, ack_id, label):
Wartet auf Socket.IO ACK.
Engine.IO message packet: 4
Socket.IO ack packet: 3
ACK-ID 0 Beispiel: 430[{"status":1,...}]
ACK-ID 1 Beispiel: 431[{"status":1,...}]
expected_prefix = "43{}".format(ack_id)
deadline = time.time() + REQUEST_TIMEOUT
last_packets = []
while time.time() < deadline:
packets = polling_get(session, url, params)
last_packets = packets
if packet == "2":
# Engine.IO ping -> pong
polling_post(session, url, params, "3")
continue
if packet == "40" or packet.startswith("40"):
# Socket.IO namespace connected
continue
if packet.startswith(expected_prefix):
payload = packet[len(expected_prefix):] or "[]"
try:
return json.loads(payload)
except Exception:
raise Exception("ACK {} konnte nicht als JSON gelesen werden: {}".format(label, packet))
if packet.startswith("44"):
raise Exception("Socket.IO Fehlerpaket bei {}: {}".format(label, packet))
time.sleep(0.05)
raise Exception(
"Timeout beim Warten auf Socket.IO ACK: {}\nLetzte Pakete:\n{}".format(
label,
pretty(last_packets),
def assert_ack_ok(ack, label):
main = ack[0] if isinstance(ack, list) and ack else ack
if not isinstance(main, dict):
raise Exception("Unerwartetes ACK-Format bei {}: {}".format(label, pretty(mask_sensitive(ack))))
# SeaTable liefert status typischerweise als 1 oder true.
if not main.get("status"):
raise Exception("Socket ACK fehlgeschlagen bei {}: {}".format(label, pretty(mask_sensitive(ack))))
def send_operation_via_engineio_polling(access, operation):
Minimaler Socket.IO/Engine.IO-v4-Polling-Client nur mit requests.
Keine externe socketio-Library erforderlich.
session = requests.Session()
socket_url = "{}/api-gateway/socket.io/".format(access["server_url"])
base_params = {
"EIO": "4",
"transport": "polling",
"dtable_uuid": access["base_uuid"],
"lang": SOCKET_LANG,
"t": str(int(time.time() * 1000)),
# 1) Engine.IO öffnen
open_response = session.get(socket_url, params=base_params, timeout=REQUEST_TIMEOUT)
if not open_response.ok:
raise Exception(
"Socket.IO Open Fehler: HTTP {} {}".format(
open_response.status_code,
open_response.text[:1000],
open_packet = parse_engineio_open_packet(open_response.text)
sid = open_packet.get("sid")
if not sid:
raise Exception("Socket.IO SID fehlt im Open-Paket: {}".format(pretty(open_packet)))
params = dict(base_params)
params["sid"] = sid
# 2) Socket.IO Namespace verbinden
polling_post(session, socket_url, params, "40")
# 3) join-room(base_uuid, base_token) mit ACK-ID 0
join_payload = "420{}".format(compact_json([
"join-room",
access["base_token"],
polling_post(session, socket_url, params, join_payload)
join_ack = wait_for_socket_ack(session, socket_url, params, 0, "join-room")
assert_ack_ok(join_ack, "join-room")
# 4) update-dtable(base_uuid, operation_as_json_string) mit ACK-ID 1
update_payload = "421{}".format(compact_json([
"update-dtable",
compact_json(operation),
polling_post(session, socket_url, params, update_payload)
update_ack = wait_for_socket_ack(session, socket_url, params, 1, "update-dtable")
assert_ack_ok(update_ack, "update-dtable")
# 5) Sauberer Disconnect. Fehler hier sind irrelevant, weil update_ack schon ok war.
try:
polling_post(session, socket_url, params, "41")
except Exception:
pass
return {
"mode": "engineio-polling",
"join_ack": mask_sensitive(join_ack),
"update_ack": mask_sensitive(update_ack),
# VERIFIKATION
def verify_result(access, expected_sorted_options, original_options):
expected_ids = option_ids(expected_sorted_options)
last_actual_ids = None
last_options = None
for _ in range(VERIFY_RETRIES):
_, current_column = fetch_current_column(access)
current_data = current_column.get("data") or {}
current_options = current_data.get("options") or []
actual_ids = option_ids(current_options)
last_actual_ids = actual_ids
last_options = current_options
if actual_ids == expected_ids:
assert_same_options_before_after(original_options, current_options)
return current_options
time.sleep(VERIFY_SLEEP_SECONDS)
raise Exception(
"Reihenfolge wurde nicht wie erwartet gespeichert.\nErwartet:\n{}\nTatsächlich:\n{}\nLetzte Optionen:\n{}".format(
pretty(expected_ids),
pretty(last_actual_ids),
pretty([option_identity_minimal(option) for option in (last_options or [])]),
# MAIN
def main():
print("Sortiere Select-Optionen ohne Löschen/Neuanlegen via modify_column_data.")
print("Tabelle:", TABLE_NAME)
print("Spalte:", COLUMN_NAME)
print("DRY_RUN:", DRY_RUN)
print("CONFIRM_UNDOCUMENTED_SOCKET_OPERATION:", CONFIRM_UNDOCUMENTED_SOCKET_OPERATION)
print("Sortierung:", SORT_DIRECTION)
access = get_base_access()
table, column = fetch_current_column(access)
column_type = column.get("type")
if column_type not in ("single-select", "multiple-select"):
raise Exception("Spalte ist keine Single-/Multiple-Select-Spalte: {}".format(column_type))
table_id = table.get("_id") or table.get("id")
if not table_id:
raise Exception("Table-ID fehlt in Metadata für Tabelle: {}".format(TABLE_NAME))
column_key = column.get("key")
if not column_key:
raise Exception("Column-Key fehlt in Metadata für Spalte: {}".format(COLUMN_NAME))
column_data = copy.deepcopy(column.get("data") or {})
options = column_data.get("options") or []
sorted_options = sort_options(copy.deepcopy(options))
validate_options(sorted_options)
assert_same_options_before_after(options, sorted_options)
changed = option_ids(options) != option_ids(sorted_options)
print_options("Aktuelle Reihenfolge", options)
print_options("Neue Reihenfolge", sorted_options)
print("")
print("Table-ID:", table_id)
print("Column-Key:", column_key)
print("Column-Type:", column_type)
print("Optionen gesamt:", len(options))
print("Reihenfolge ändert sich:", changed)
print("Optionsmenge/IDs/Metadaten unverändert geprüft: True")
print("Zellwerte werden nicht gelesen und nicht verändert.")
backup = {
"table_name": TABLE_NAME,
"table_id": table_id,
"column_name": COLUMN_NAME,
"column_key": column_key,
"column_type": column_type,
"sort_direction": SORT_DIRECTION,
"options_before": options,
"options_after": sorted_options,
if PRINT_BACKUP_JSON:
print_section("Backup / Vorher-Nachher-JSON")
print(pretty(backup))
if not changed:
print("")
print("Bereits sortiert. Keine Änderung nötig.")
return
new_column_data = copy.deepcopy(column_data)
new_column_data["options"] = sorted_options
operation = {
"column_data": new_column_data,
if PRINT_OPERATION_JSON:
print_section("Geplante Operation")
print(pretty({
"op_type": operation["op_type"],
"table_id": operation["table_id"],
"column_key": operation["column_key"],
"column_data": {
"options": [option_identity_minimal(option) for option in operation["column_data"].get("options", [])],
if DRY_RUN:
print("")
print("DRY_RUN = True. Es wurde nichts geändert.")
return
if not CONFIRM_UNDOCUMENTED_SOCKET_OPERATION:
raise Exception(
"Abbruch: CONFIRM_UNDOCUMENTED_SOCKET_OPERATION ist False.\n"
"Für echte Änderung bewusst setzen:\n"
" DRY_RUN = False\n"
" CONFIRM_UNDOCUMENTED_SOCKET_OPERATION = True"
print("")
print("Sende modify_column_data via Engine.IO-Polling / update-dtable...")
result = send_operation_via_engineio_polling(access, operation)
print_section("Socket-Ergebnis")
print(pretty(result))
print("")
print("Prüfe gespeicherte Optionsreihenfolge...")
verified_options = verify_result(access, sorted_options, options)
print_options("Gespeicherte Reihenfolge nach Update", verified_options)
print("")
print("Fertig. Optionen wurden ohne Löschen/Neuanlegen sortiert.")
main()
