In the last days, when I copy a cell with “long text” in the end of each paragraph I get strange characters:
any Idea why?
Hello,
can you please describe in more detail how you copy the column? By button, into another table and into which column type?
  is the unicode hex character code for space.
It seems that you have a space at the end of your lines.
The immediate fix is to remove them.
@Leo.Shi Could we fix that code-side?
Thanks for replies.
I’m copying the cell using ctrl+C .
It happens only in the end of paragraph (not every time I use space).
It seems that deleting the space in the end of the sentence does helps.
I will update if the problem repeats.
