Sum column of an array column
Hello everyone,
is there an easy way to sum up values of arrays with a formula-column?
Unfortunately, for me it’s possible to get only the first value of the array with {Values}.
Thanks,
Oliver
Please use a link formula column with a roll-up instead of a “normal” formula column. (It’s the more direct way anyway.)
Hi rdb,
with your tip I figured it out after 20 minutes.
I desperately tried to make a rollup from a different linked table. The rollup works perfectly in the table with the records.
Thank you!
