Tldraw doesn't work
good afternoon
tldraw doesn’t work
what should I do? I’ve already checked everything, but I couldn’t find detailed installation instructions. it just hangs and doesn’t do anything.
{“status”:“pong”} I have it, but the app doesn’t work
установлен seatable 5.2.7
/opt/seatable-compose/tldraw.yml
services:
  tldraw-worker:
    image: ${TLDRAW_IMAGE:-seatable/tldraw-worker:2.0.1}
    container_name: tldraw-worker
    restart: unless-stopped
    command: yarn docker
    environment:
      - SEATABLE_SERVER_URL=${SEATABLE_SERVER_PROTOCOL:-https}://${SEATABLE_SERVER_HOSTNAME:?Variable is not set or empty}
    labels:
      caddy: ${SEATABLE_SERVER_HOSTNAME}:${TLDRAW_PORT:-6239}
      caddy.reverse_proxy: "{{upstreams 5858}}"
    networks:
      - frontend-net
    healthcheck:
      test: ["CMD-SHELL", "curl --fail http://localhost:5858/ping || exit 1"]
      interval: 30s
      retries: 3
      start_period: 60s
      timeout: 5s
/etc/nginx/sites-enabled/nginx-seatable.conf
server {
	listen 443 ssl;
	server_name base.xyz.su;
	ssl_certificate /etc/letsencrypt/live/base.xyz.su/fullchain.pem;
	ssl_certificate_key /etc/letsencrypt/live/base.xyz.su/privkey.pem;
	location / {
		proxy_pass http://127.0.0.1:9705; # Порт
		proxy_set_header Host $host;
		proxy_set_header X-Real-IP $remote_addr;
		proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
		proxy_set_header X-Forwarded-Proto $scheme;
		proxy_read_timeout 90;
	location /tldraw/ {
		proxy_pass http://127.0.0.1:6239/;
		rewrite ^/tldraw/(.*)$ /$1 break;
		# 🔥 WebSocket поддержка!
		proxy_http_version 1.1;
		proxy_set_header Upgrade $http_upgrade;
		proxy_set_header Connection "upgrade";
		# Стандартные заголовки
		# Отключить буферизацию
		proxy_buffering off;
server {
	if ($host = base.xyz.su) {
		return 301 https://$host$request_uri;
	} # managed by Certbot
	listen 80;
Have you check the container log output (as instructed in the manual)?
Which SeaTable Server edition do you run?
seatable 5.2.7
it says Whiteboard - SeaTable Admin Manual that if you don’t see the message then in the log, but I have a message, the log is empty
maybe there are more detailed instructions?
Ok, you are using Enterprise Edition.
I would argue that log files are super helpful for debugging. If the docker log for the tldraw container does not help, check the other logs.
This are the instructions: Whiteboard - SeaTable Admin Manual
