hello users, I have been trying to setup my seatable server with ubuntu 24 as a WSL, everything is correct according to the admin manual, the terminal also shows the server starting correctly. I bought a domain at a site called “site.nl” and the domain is “guanabania.nl”. In the .env file I listed it, as per the tutorial as “seatable.guanabania.nl”. I would like to use the seatable server for a plethera of things for a bunch of different people and organisations. I hope ya’ll can help.
Dear Zecu,
there is no DNS-Entry for seatable.guanabania.nl. Due to this obvious reason this will not work. Also your description sounds like you’re running SeaTable locally but expect to be reachable publicly. This will not work.
From your description, I assume that you don’t have any experience with running your own server, right? If this is the case, please use cloud.seatable.io instead. You will avoid a lot of headache.
Best regards
Christoph
