Unable to get linked records (base.get_linked_records)
Problem
A Python script. Although I have table_id, link_column_key, and rows which are required for base.get_linked_records() as described in https://developer.seatable.io/scripts/python/objects/links/#get-link-id, I am getting an error. The code has the fetched values as comment for you to check if they’ve got the right format, and you can also find the error message as final comment. I’ve also attached a screenshot which proves there is a linked record in the ‘master’ column.
I’ve also tried to use table and column names instead of keys, but this seems only to be possible in the API. I’ve also tried to omit the rows= explicit parameter name in front of simply providing the JSON-ish list of rows (which is a one-list in my case).
Script With Error Message As Comment
base.auth()
lang_table = context.current_table
lang_table_id = next((table['_id'] for table in metadata['tables'] if table['name'] == lang_table), None)
link_column_key = base.get_column_link_id(lang_table, 'master')
lang_row_id = context.current_row['_id']
rows_list = [{'row_id': lang_row_id}]
debug_lang_keys = (
    f"lang_table_id: {lang_table_id}, \n"      # 2j7j
    f"link_column_key: {link_column_key}, \n"  # j6jR
    f"lang_row_id: {lang_row_id}, \n"          # ZYuI7cT7T6iYOwPkLMePKA
    f"rows_list: {rows_list}, \n"              # [{'row_id': 'ZYuI7cT7T6iYOwPkLMePKA'}]
try:
    json = base.get_linked_records(lang_table_id, link_column_key, rows=rows_list)
    debug_lang = f'SUCCESS: \n\n{debug_lang_keys}json: {json}'
except Exception as e:
    debug_lang = f'ERROR: Failed to fetch linked records.\n\n{debug_lang_keys}\n Exception: {str(e)}'
lang_row_data = {'debug': debug_lang}
base.update_row(lang_table, lang_row_id, lang_row_data)
# Exception: [Errno 400] {"error_message":"failed to get column for table: 2j7j,
# name: [],key: [j6jR] in base 31994138-1ca3-48cf-a094-3871012c0053: column not exists"}
SeaTable
Maybe a related issue which hasnt’t been answered yet: https://forum.seatable.io/t/note-able-to-recover-again-columns-with-more-than-10-elements-in-a-row/3255
Hi,
The error might be caused by link_column_key = base.get_column_link_id(lang_table, 'master') which returned is link_id of link_column instead of column_key. The code can be modified like below
lang_table = next((table for table in metadata['tables'] if table['name'] == lang_table), None)
lang_table_id = lang_table['_id']
link_column = None
for col in lang_table['columns']:
   if col['name'] == 'xxxxx':
       link_column = col
       break
link_column_key = link_column['key']
Please try it again, and this might solve the problem
@fritzfeger Can we close the issue?
Yes, and thank you @r350178982! I should have looked into the metadata JSON …
A more pythonic way than the loop:
lang_table = next((table for table in metadata['tables'] if table['name'] == lang_table_name), None)
link_column = next((col for col in lang_table['columns'] if col['name'] == 'master'), None)
link_column_key = link_column['key'] if link_column else None
