Unresponsive areas after using the map plugin on chrome
[Using SeaTable Cloud / Google Chrome]
After installing the map and several other plugins, I added a couple of lat/long locations, tried to view the entries with the map plugin, the map was only partially visible, then a lot of the base interface became unresponsive.
I was not able to click on the plugin options (ie to delete or add to toolbar) or click on the column header drop downs, plus a few other restrictions. The console gave these errors:
Hard refreshing and clearing the site data, updating Chrome, logging out and back in didn’t resolve the issue.
To fix it, I accessed the base through Safari and was able to remove the plugin that way. Returning to Chrome everything is working fine again now.
It seems that this issue is not caused by SeaTable, but a browser extension of yours: javascript - "A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received", What does that mean? - Stack Overflow
