I have the weird phenomenon with currently one user (out of about 400) which cannot bei seen from the sharing dialog. The user can log in (against our LDAP / AD), can use Seatable, create bases, share them to others, can be invited to bases using a link. The user also appears in the Admin backend.
However, the user cannot be seen from the “direct sharing” or “group administration” dialogues:
In the background, the https://myserver.tld/api2/search-user/?q=oliver XHR call just returns an empty array. I tried everything I could think of:
Use different browsers
Erase the user completely, and have him log in again
Couldn’t find any other users which behave similar
Even checked the ccnet_db.EmailUser and dtable_db.profile_profile to find any obvious differences to other users
So here’s my question: Is there any way I can debug (log files etc.) the /api2/search-user/ API call. i imagine that that is the culprit.
Added information: On our test system which is largely similar (same user base from LDAP), the same user can be found with no problem. Assuming a corrupted user entry in our production system, I’d really like to find the problem in order to assure reliability.
It turns out for historic reasons unknown, that I have a lot of entries in the dtable_db.profile_profile table that have no equivalent entry in the ccnet_db.EmailUser table (as linked between the email and user columns).
Talking SQL - this statement reveals all these orphan entries in dtable_db:
select dtb.nickname,dtb.user,cdb.email
from dtable_db.profile_profile as dtb
left join ccnet_db.EmailUser as cdb
on cdb.email=dtb.user
where isnull(cdb.email);
First questions:
Should this statement per definition create an empty list, i.e. every single entry in profile_profile should match one in EmailUsers?
Does anyone else have a system with a non-empty list when running the above SQL statement?
I cannot exactly tell what the origin of these entries are; maybe they come from some faulty or changing LDAP login, maybe they originated from bugs in previous Seatable versions. However, those ophan entries come in different types:
One or multiple entries in profile_profile, and not a single corresponding entry in EmailUsers
They are obviously residue from users that have been deleted, but remained in profile_profile
One or more valid records with corresponding records, and lots of orphans in profile_profile
Those where the ones that blocked the re-usage of E-Mail-Addresses in my other post.
The orphans seem to creep up in quite some numbers - the record was 40(!) for one user
Second set of questions towards Seatable
Is this a known problem, or by design? At least when a user is deleted, are entries purged both from the EmailUsers and profile_profile tables?
Should there be no ophans in profile_profile?
Can I fix this safely with the following SQL statement?
/* non-destructive: Set Nickname to something nobody will search for */
update dtable_db.profile_profile dtb
left join ccnet_db.EmailUser cdb
set dtb.nickname = 'jljsdjlmi8hjwej'
/* destructive: Delete orphans */
delete from dtable_db.profile_profile
where dtable_db.profile_profile.user not in
(select distinct ccnet_db.EmailUser.email from ccnet_db.EmailUser);
Finally comes the explanation how this relates to the original post: The API endpoint /api2/search_user/ seems to have a limit of 10 entries to retrieve from the profile_profile table when making a quick lookup in the “share” dialogue. This, in my case, returns 10 orphans, and not the valid one from the table. Only then are the 10 entries from profile_profile validated again EmailUsers - resulting in NO results.
After I found out how this works, I found more users where this applies.
Thanks! That’s enough for me to keep going until you have researched the main issue. I assume that you run much bigger systems than I do. If you don’t have the same phenomenon, and nobody else does, that’s probably a problem caused by our sometimes unstable LDAP / AD integration.
If you find the same issue in one of your own systems, you should have enough data for debugging.
