In SeaTable, a user is identified by its username (i.e. abc123…xyz@auth.local). You find more information on the username at Overview - SeaTable Admin Manual.
In collaborator, creator and last modifier columns as well as in comments, SeaTable uses a user’s username to refer to a user.
When a user is deleted from SeaTable, the username does not cease to exist. But the information that the user behind the username abc123…xyz@auth.local was name, for instance, “Max Mustermann” is deleted.
Hence, after deleting a user, you will see the username in all places where the user’s display name was previously shown.
Bases belonging to a deleted user a moved to trash and deleted permanently after 30 days.
Rows created by the deleted user in bases belonging to other users and groups will NOT be affected.
Disactiving a user and deleting a user are two completely different things. A user whose status was set to “inactive” cannot log into their account. But the user continues to exist in the system and, as a consequence, the inactive user can still be invited to bases/apps and referenced in collaborator columns.
