Is there a way to keep from vertical center on a table that it is in page design. It have to reduce the font size due to it erasing part of the text when it is large enough to be readable
I am on seatable cloud
any help appreciated
Hi @dwright,
Sorry I don’t really understand what you mean
. You can define Row font size and Row height but there are small, non-compressible top and bottom margins around the content of each cell.
In order to save some vertical space, I’d rather deal with your custom header: it looks like it uses three lines whereas you could probably get rid of am/pm as it’s quite obvious looking at the data. Besides, using the built-in table header will probably allow you to do something more compact.
Bests,
Benjamin
my employer uses a paper time sheet so mine has to look exactly like theirs.
if i have the date coming off of the top instead of being centered, it looks like that would take care of it. Is this possible?
