Web forms created under "my bases"
When you create a webformular in a base under “my bases” and copy the base to a group, the webformular does change its URL. Therefore, it will become difficult to build a base under your private environment and copy it to group workspace later, because you have to check all the links, e.g. when you already prepared draft e-mails
This is the expected behavior.
When you copy a base, you create a new base. The forms are linked to the new base and hence they need new URLs. (If they weren’t, they link to the old base and you’d probably complain that the forms are not copied.)
