Webform specific to a particular respondent/table row
Is it possible on SeaTable to send a webform link to a particular row entry (person/attendee), so that they could add additional form data or update data, without them seeing anyone else’s information?
The submission of a web form creates a new record. You cannot modify an existing record using a web form.
For the use case you have in mind, please use an app.
Hi @ashvis ,
Check this post for an alternative solution that might eventually fit your needs.
Bests,
Benjamin
