When adding/modifying/delete data in ST table, but an SQL SELECT query returns old data.
Your Setup:
  • Hardware or environment you use - Virtual Mashine with RH8
  • SeaTable Edition (Developer or Enterprise) - enterprise edition
  • SeaTable Version (only necessary for self-hosted): 5.2.7
Only the initial data from table creation is visible; recent changes are not reflected. After 24 hours, the updated data becomes visible, but subsequent modifications still show outdated values.
Reproduce:
  • create database
  • add data into table - works correctly
  • run ‘SQL query’ plugin (or api sql select request - same result)
  • all data is visible in the SELECT results
  • add/modify/delete any data into table - operations complete successfully
  • again run ‘SQL query’ plugin (or api sql select request, no matter)
  • only see the data as it was when the table was created; none of the changes are reflected. The next day, the data starts appearing, but when modified again, we only see the old values.
Error Messages:
No error messages for any steps
This is not the default behavior.
Are there any error messages visible in logs or the browser console?
Thanks for the answer :slight_smile:
No error was into browser.
After restarting the server, the issue disappeared and we are unable to reproduce it.
I suggest considering it resolved.
