Yet another comma issue
Hi,
I just found a new comma issue. When adding data via a form in an universal app, the comma is ignored and a dot is used as decimal delimiter. 1,00 becomes 100.00.
Tested in 4.2.10 enterprise on-prem and hosted version today.
It works in the old web forms.
Please also check this example. Log in or signup - SeaTable Cloud
Regards,
@Leo.Shi I confirm the issue.
Thank you for your feedback. :smiley:We will fix it in the next version.
Thanks.
Any chance that you release the fix before you release 4.3?
This broke most of my forms. Also I guess I am not the only one using decimal numbers with comma delimiter in forms. :wink:
Still the same with the newest release (4.2.11).
This means SeaTable 4.3.
Hello,
Even if the topic is from last year, I have right now the exact same issue.
Is that a known issue ?
I will put my numbers with dot separator waiting for the next update.
Thanks to developers.
I can confirm the issue: Euro values get the factor 100x, i.e. 10,45 Euro in an App-Form will lead to a 1.045,00 Euro in the table.
